Inventor Forum
Studio render is making one part shiny and the rest not
5 REPLIES 5
greghughes
508 Views, 5 Replies
The parts in my assembly all use the same appearance. When I come to to do a render of my model however it is rendering one of these shiny (I think thats what it called).
See attached images
Image1 shows how I want it to look (this is the opposite end of my assembly)
Image2 shows the problem
Image3 shows a different appearance give to the problem part
The problem part is derived from the other end of the assembly (the part show in image1). All the parts at this end of the assembly are created the same way. They all render fine its just this one.
I have tried recreating the part but still end up with the same result
This is doing my head in! Any suggestions greatly appreciated
Cheers
Greg
5 REPLIES 5
blair
in reply to: greghughes
Does changing the appearance in Studio make any difference to the render outcome?
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
greghughes
in reply to: blair
Tried that - same result
I've sidestepped some similar-ish issues in studio (2012 & 2013) by opening the part and faux-editing part features. (as in hit edit, then leave everything unchanged and press OK)
I guess this forces a full rebuild of the part in the graphics memory.
(My issues were related to small sharp grooves in a stair nosing)
greghughes
Thanks for your suggestion - I have tried this and it doesnt fix the problem
Cheers
Greg
Can you able to share the assembly with us.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
