Inventor General Discussion
Distinguished Contributor
Josh_Petitt
Message 11 of 18 (148 Views)
Re: Studio Reflective Gp shows cut reflection
07-26-2006 02:04 PM in reply to: mf1362
can you post a pic of the screen before you render?
*Randy Kreitzman (Autodesk)
Message 12 of 18 (148 Views)
07-26-2006 02:46 PM in reply to: mf1362
Marco,
Could you try inserting an extruded rectangle into the scene, assign it
a highly reflective surface style, and place it beneath your assembly?
This may be an issue with how big your assembly is in relation to the
Inventor universe. The shadow/reflection plane isn't infinite, but it
is very, very big.
I wouldn't expect to see this phenomenon unless the assembly were huge.
Thank you,
-Randy
mf1362 wrote:
> Results don't vary when zooming in or out, the plane looks complete before rendering
mf1362
Message 13 of 18 (148 Views)
07-26-2006 03:43 PM in reply to: mf1362
see attached pic before rendering -Marco
mf1362
Message 14 of 18 (148 Views)
07-26-2006 03:52 PM in reply to: mf1362
Well, I did a new rendering with an extruded 12" rectangle, and the shadow & reflection look good. But when I removed the bar it came back to the same cut reflection. (weird). see attched files
-Marco
mf1362
Message 15 of 18 (148 Views)
07-26-2006 03:53 PM in reply to: mf1362
Here's the other pic
Message 16 of 18 (148 Views)
07-26-2006 04:04 PM in reply to: mf1362
It looks like the shadow/reflection plane is, in part, defined by the
extents of the scene geometry. Try placing any renderable geometry out
of the camera view but a good distance away from your assembly.
-Randy
R.Corriveau
Message 17 of 18 (148 Views)
07-27-2006 07:44 AM in reply to: mf1362
Couldn't or can't?
If you can then roll up the EOP, Zip and post.
Active Member
DanielLongo
Message 18 of 18 (104 Views)
01-03-2013 05:51 AM in reply to: *Randy Kreitzman (Autodesk)
I had the same issue and knew it must have had something to do with the size of the assembly. Mine was a full-size combined cycle power facility that I was rendering to an existing site image. It was just big enough that when offset to a side of the background image that the shaddows would be clipped.I will try creating a derived assembly at half-size for the scene.
