Inventor General Discussion
mf1362
Message 1 of 18 (155 Views)
Studio Reflective Gp shows cut reflection
155 Views, 17 Replies
07-25-2006 04:00 PM
I have a problem with Inventor 11 Studio. The reflection on the ground made by "XZ Reflective Gp" works in a way that when rendered, it shows a partial or cut reflection of my assembly, see attached .jpg file. I have not found yet where this "reflection depth" is regulated. Please help! -Marco
Distinguished Contributor
rblawson
Message 2 of 18 (155 Views)
Re: Studio Reflective Gp shows cut reflection
07-26-2006 06:42 AM in reply to: mf1362
In studio, go to Scene Styles, select your scene, then on the Environment tab, select the Ground Plane direction and offset.
-barrett
mf1362
Message 3 of 18 (155 Views)
07-26-2006 10:30 AM in reply to: mf1362
I tried that before, but as you can see in the attached .jpeg file, the problem is not the degree of reflection or the distance of the plane to the base of the object, the problem is the reflection is not shown entirely on the rendering, it is cut across the bottom of it. -Marco
mf1362
Message 4 of 18 (155 Views)
07-26-2006 10:32 AM in reply to: mf1362
...and this is also happening to the shadow, as you can see. -Marco
R.Corriveau
Message 5 of 18 (155 Views)
07-26-2006 11:05 AM in reply to: mf1362
Hi Marco,
Could you post the part?
*Gary R Smith \(Autodesk\)
Message 6 of 18 (155 Views)
07-26-2006 12:31 PM in reply to: mf1362
Does this behavior manifest in all renderings or only of this part?
Have you tried rendering using any of the other reflective planes? Do they
clip too?
When you click on the render button, does the plane appear to be full-sized?
Message 7 of 18 (155 Views)
07-26-2006 12:34 PM in reply to: mf1362
How big is the part?
Do your results vary if you zoom out on the part? Can you get "more"
reflection/shadow to render?
mf1362
Message 8 of 18 (155 Views)
07-26-2006 12:54 PM in reply to: mf1362
a .jpeg is posted, couldn't post a 3d file (?) -Marco
mf1362
Message 9 of 18 (155 Views)
07-26-2006 12:56 PM in reply to: mf1362
It happens only on this part so far, but I only have a couple of days experience with Inventor studio, so I have done about 6 parts so far
mf1362
Message 10 of 18 (155 Views)
07-26-2006 12:57 PM in reply to: mf1362
Results don't vary when zooming in or out, the plane looks complete before rendering
