Bill,
Bob,
I don't know which component is failing. Probably best if I post the file to
a FTP site . Zipped it's over 27 mB.
It's a proprietary design so I'll have to contact you directly to advise
which FTP site to access.
Thanks.
Gary
"Bill Bogan" wrote in message
news:5037291@discussion.autodesk.com...
Gary,
Do you have a feel for which component is failing at that time? If not
that's OK I was just wondering.
It will probably take sending us the dataset so we can analyze the animation
and see what is happening.
Is the dataset very large?
_______________________________
Bill Bogan
Product Designer - Autodesk Inventor
Manufacturing Solutions Division
"Gary Cross ( IV10 SP2)" wrote in message
news:5037187@discussion.autodesk.com...
Quinn,
Quinn,
I found some adaptivity that was not turned off but turning it off did not
solve the problem, unfortunately.
I am purposely not animating any constraints since I seem to always run into
conflicts with animating motion.
It shuts down at the transition of one motion to another as you can see but
no matter how I manipulate those I still get the error.
Gary
"Quinn Zander" wrote in message
news:5037087@discussion.autodesk.com...
The image doesn't say too much but it would seem that a constraint in there
is probably unsuppressing itself by mistake at that time segment.(5.1s)
Since the animation runs until this time, that would indicate that all your
"starts" (at 0s) aren't conflicting.
Are you trying to run with adaptivity? If you are, make sure the
workfeatures (if used) are indeed adaptive and that you are also animating
thier constraints.
QBZ
