Inventor General Discussion
29 Kudos
Post 1 of 3
Stuck on JD Mather tutorial
927 Views, 2 Replies
12-21-2012 04:12 AM
Greetings all
I am working my way through JD Mather's tuts, thanks to the project files he very speedily sent me.
I am on tut 11, cylindrical cam, point 10 - Extrude the outer ring to the spline surface.
Everything else has gone like clockwork, but I now get "extrusion distance is zero.Use Edit Extruded Feature to change the extrusion distance."
I have re-tried a couple of times up to this point, but I can't see what I'm missing.
I will attach my attempt.
P.S. I have learned more about surfaces in 2 days than in the last 6 months of using/abusing Inventor.
- Inventor 2013 Pro
Looks like the behavior has changed since I wrote that tutorial.  The direction arrow is wrong.  (looks like a bug in the progam to me)
Try using Between instead and select the end of the cylinder and select the surface.
BTW- there are now two different and easier techniques to model this cam.
In a later release the Sweep with Guide Surface functionality was added
and then
later a Cylindrical Cam Design Accelerator was added.
There might be some related use of this more complex technique that makes it still relevant.
2,122 Kudos
Post 2 of 3
Re: Stuck on JD Mather tutorial
12-21-2012 05:34 AM in reply to: BarryZA
and then
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
29 Kudos
Post 3 of 3
12-22-2012 05:33 AM in reply to: JDMather
Thank-you again, I just knew the solution was going to fall into the "minor point that I should have worked out on my own" category.
And I really enjoyed the vacuum tutorial, it made me realize how badly I have been modelling.
