I'm working in Inventor R2011. I need to export a BOM which will show the quantity of each part and assembly in the model. As far as I know, my choices are Structured (All Levels) BOM or Parts Only BOM. The Structured BOM is "structured" (see what I did there...) to show the quantity of each of the sub-assemblies, then the quantity of parts in each sub-assemby, so there is no TOTAL quantity of the component in the model, only a quantity of the component in its parent sub-assembly. Can I make a BOM that shows the total quantity in the model?
Solved by mcgyvr. Go to Solution.
I think what you want is a "summarized" BOM..
Inventor does not do that..
Parts only is "close"though.. but it does not include the subassembly part numbers.
This might help you have a workaround..
http://forums.autodesk.com/t5/inventor-ideastation/summarized-bom-to-cut-a-work-order/idi-p/4346553
