We use Autodesk Inventor (Product Design Suite) to design our products. Our products are pretty big and have to anchored and supported on side with structural steel. We have been designing the layout of our product on Autodesk Inventor but have not been modeling the structual steel in it.
The reason is that Autodesk Inventor did not seem very friendly with steel design and detailing for fabrication at all. However, we definitely would like to model everything (our product and the steel) as a main layout in Autodesk Inventor. From this complete layout, we would like to create fabrication prints for the steel as well. Does autodesk have a package that would help us accomplish what we want to do?
Solved by dgorsman. Go to Solution.
Are you using Frame Generator for your steel work?
Inventor does not have anything specific for Structural layout and detailing, though I think you could do it with FG, and possibly export the drawings to Autocad for detailing? The other possibility would be to design the products in Inventor, and look into Plant 3D for the structural side. The product models can be exported to Plant 3d (I'm not familiar with the procedures). I might suggest posting a similar question on the Plant 3D forum and get some opinions from users there as to whether it would be a good move for you.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I have tried using Frame Generator. It is okay for steel design but still does not help you in steel detailing.
What does FG stand for? Could you make me clear on the capabilities Plant 3D has? I will try posting a question there.
autocad structural detailing may also do what you want
http://www.autodesk.com/products/autocad-structural-detailing/overview
your going to have to post your questions about this product in the product forum
http://forums.autodesk.com/t5/AutoCAD-Structural-Detailing/bd-p/346
DarrenP
Plant 3D only has basic layout abilities. If Inventor doesn't do it for you, Plant 3D certainly won't (it assumes you will be using something else for detailed structural design). For dedicated structural steel design tools, you will likely be looking at one of the Revit or MEP packages. Of course, as you get further into tools for dedicated design work, the more difficult it will be to communicate between the different programs.
When you say IV what does it mean? Is it "Autodesk IV"? Because I could not find such package online.
IV is Inventor
DarrenP
@filso wrote:
Please Autodesk, make this feature for the 2015 Inventor upgrade!!!
By this time 2015 is probably well into Beta (functionality set and in testing). If it isn't in there now, you should be posting this to the idea station.
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
for best Best WorkFlow for steel you got three steps, revit structure>Analyis in Robot Structure Analysis >Autocad Structure Detailing for Advanced Detailing, you ll had best Results
Jean,
Would you kindly send me links to the customizations you use?
I need to learn how to do this.
My Inventor is 2010Suite.
Thanks ...
@cadman777 wrote:Jean,
I would love to send you the links to the stuff we use but there are no links. What I mean is that all of the customizations we have developed for this (iFeatures, iParts, iAssemblies, Custom CC Profiles, iLogic programming, etc.) are all things we have developed ourselves and I am not able to give out. I can certainly point you to some of my replies to others about this that point out the general process, but we've spent 5 years and a whole bunch of money developing what we need and I am forbidden from giving it out. I am happy to help you along the way if you are interested in developing this stuff yourself but the links below should give you some idea of what we have done.
Good Luck!
How to Handle Structural Bracing
Example of One of the Largest Structures We've Done
