I have created a few new structural parts that I am in the process of publishing to the content center.
I got one of them in and have it working very well except for one item. If I place this structural piece
into an assembly as a stand alone part just selecting the length and the material as the key inputs,
it shows the proper length in the part number and the description just fine. If I insert this same structural
piece in a skeleton using the frame generator, then the length that shows up in the description is the default
one that the part was originally created to. How do I get the length to show up in the frame BOM correctly when parts are created using the frame generator?
This works using the structural members out of the box.
Solved by alessandro.gasso. Go to Solution.
I am wondering if it has something to do with the G_L parameter, yet I can't seem to place my finger on it.
Still welcome some feedback on this.
After setting the description in the CC editor to look like this
It gives me thewse results when creating a frame using the frame generator.
Yet with the same settings if I just insert these parts and specify a specific length when inserting them from CC
I get this.
Which is what I am looking for from the frame generator to give me the specific lengths based off of the skeleton and trimming. I can do this very same sequence using an out of the box structural piece from CC and the BOM will show the correct length when using the frame generator.
Why is this happening with my published structural member? What am I missing?
Anyone?
Hi Cadmanto,
Is the same issue? :
Or maybe this:
I don't have time to step through it to see exactly what you're seeing, but I have a fuzzy memory of something similar being worked out on this forum in the past, so you might find it in a search if these links don't help.
I hope this helps.
Curtis
That sounds like the same issue, but the difference I can see is he was using 2011 and I am using 2012.
Also, he could not get it to update in either an assembly or a frame generator, where as I can get it to update in an assembly, just not the frame generator.
Ok, the weekend is past and it is a new week. With that I am hoping some fresh sets of eyes will give this thread a clearer, different approach that might ultimately lead to a solution.
Hi Scott,
In this thread (http://forums.autodesk.com/t5/Autodesk-Inventor/Custom-Profile-in-frame-generator/td-p/3507830 ), I‘ve suggested the steps of the post below.
If the post doesn’t help, check you have followed the steps of the article below for publishing your custom frames.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12193815&linkID=9242016
Kind regards,
Alessandro
Scott,
I have a UniStrut in my CC that I published from the iPart on CBliss.com and I don't have any of the problems you mentioned. However I can't recall using it with Frame Generator. The one thing you are doing incorrectly for Frame Generator is using the B_L parameter for length. The B_L is for the Base Length before any FG end treatments or length adjustments. The correct parameter to use is the G_L for Geometric Length. I could export and send you the part I have if you want to try using it with FG.
Take a look at the following screen captures.
Hope this helps, Paul
Alessandro,
Thank you so much for the links. In trying to follow them I have some questions.
First, is the "STOCKNUMBER" as shown here in the one link you provided supposed to be a new colum in the CC editor?
If so what should the values be for this? I have two members to this table.
Next, with my issue being trying to get the member length to update in the description, can it be assemed that the "Demo_For_Blog" column property used in the one link you provided be what would be called my "Description" ?
Also, how does what you typed here in your one response tie in with what I typed about above regarding the other link?
What column property is this tied into?
Is it also fair to say that these parameters you are speaking of in these threads (G_L) should be selected from this list and thus imported upon publishing the part?
Thanks Paul.
The reason I went to the B_L was because after trying the G_L which didn't work, I decided to try and mimic one of the CC existing structural members (ANSI "W" Beam) and that is how they set there's up and it does work.
Which further led me to believe that there was some code I w3as either missing and couldn't see or over looking the obvious.
I am definately not having any issues getting my Unistrut members into the CC and using them as you described in just inserting them, but it is the frame generator that is messings things up. I will say that your screen shot of the different variations brings up a point that I need to ask. Like I have said I have two members (SS and Galvanized versions) and these are represented as iparts. When I publish these to CC and then use the frame generator to access them, the selections come up as "unnamed member 1" and "unnamed member 2". How do I get these to show up with the correct material names instead?
I am going to try Alessandro's suggestion to see if that gives me anything more then what I currently have.
Hi Scott,
About the first question, if you have followed, for instance, the steps from the article below for publishing your custom frame, the column Stock Number should be already available in the Family Table.
So, if you want to add it to the expression of another column, you should be able to select it from the list, as in the image below.
By the way, the key point for getting the frame length in the property is to start the expression with “=” and include in the expression “<G_L>”.
The Stock Number in my post it was just an example.
About the second question, you can read in the post below how to define the Description column.
Of course, if you want to display the frame length in the Description, you need, once again start the expression with “=” and include in the expression “<G_L>”, like in the other post.
I’m not sure I’ve understood the third question, but if you are talking about the number "3842992425", you can disregard it. This was a specific requirement of that user.
Instead, if you meant something different, please, provide me more details.
About the last question, the parameter <G_L> has to be written manually, as you can see in the video of the post (http://beinginventive.typepad.com/being-inventive/2012/04/include-the-length-from-the-steel-shape-pr... ).
If you didn’t watch it yet, please, do it.
After you have done that, inserting the frame published (once again) following the steps of the article http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12193815&linkID=9242016 , the parameter G_L with its value will be generated in the file and the value displayed in the property.
I hope I’ve clarified your doubts.
If not, please, let me know.
Kind regards,
Ale
The workflow Ale provided is the right approach.
Here are something based on my understanding may be helpful.
1. The expression starting with “=” and including parameter like <XXX> stands for a reference to model iProperties.
2. The expression including column name like this {G_L} stands for a reference to Content Center family table parameter.
3. If you’re only handling Part Number, you can directly refer the family table parameter, like {G_L}, whatever the name mapped to Base Length.
4. If you’re handling Description, you may need use the expression start with “=” and use model iProperties, i.e. <XXX>
Nicolas
Nicolas,
Thank you very much for this info. This is very useful in understanding what all of this coding actually means.
It does get confusing at times trying to remember and figure out what sequence and what characters need to go where.
Ale,
This was awesome material you provided and I can't thank you enough!!!
I got this to work with my description perfectly in both the inserted version and the frame generator version.
I do need to republish the part though to get these size designations to show up as the material callouts.
I think based on what you have given me it looks to be the stock number property from the part that needs to be
incorporated into the published part in order to be included in the code equations.
Hi Scott,
I’m glad I could be helpful.
About your last question, I don’t think you need to republish the frame.
For the custom frames in the Size drop-down menu you should see the values of the column you have defined in the family table as column key.
So, you just need to edit the Family Table and define as keys the columns you need for displaying their values in the Size drop-down menu.
I hope it helps.
Kind regards,
Ale
Thanks again Ale.
I got some success based on what you said.
But, I already had the material in the keys to begin with. So why does adding the member to the key list
work only after that and why doesn't it allow the material to be shown?
Hi Scott,
The material does not display in the Size drop-down menu, even if selected as key column, because the one in the cell corresponding to the size selected it displays anyway as default one in the Material drop-down menu below (Carbon Steel in your image).
I hope it makes sense for you.
Kind regards,
Ale
Hi Ale,
That makes sense.
What I did was just create an extra column in the family table and set the values to be the materials I needed.
I made that a key column and now that shows up in the "Size" selection within the frame generator.
The correct material is being selected as far as the physical properties go as well.
Thank you so much for your help.
You are welcome and nice trick for getting the material in the Size menu, by the way.
Kind regards,
Ale
Ale,
Thanks.
I have another question. Is there a way to controll the amount of decimal places in the length that
show up in the description.
