Inventor Forum
Stretched 3D solids goes to infinity
1 REPLY 1
martin
568 Views, 1 Reply
I have a serious issue with the graphics in Autodesk Inventor 2012 (educational), more specifically any solid shapes. It is really wired so please view the images to get a picture of it. Any solid shape just tend to go to the right no matter what angle you look at it and as it seems to go towards towards infinity (or it is just really, really long). This is in orthographic view I might add. In perspective view the cube ends within the screen but it far from cubical and changes its appearance as you rotate it. As you can see in the pictures even the axis graphics down to the left is messed up.
Picture one is while I am extruding the 10mm cube. The big orange thing is the arrow used to drag up from the sketch.
Picture two is just the 10mm cube. As you can see the wire frame works just fine and it event hides the edges behind the solid.
I just installed the software on this computer so I suspect it is my graphics card that simply cannot handle the 3D solids. It is a few years old, a NVIDIA Quadro FX 540. The shadows does not work either, probably because I do not have shader model 2.0 or newer.
So, can this be fixed somehow or do I have to scrap my computer?
1 REPLY 1
JDMather
in reply to: martin
Try going to Tools>Application Options>Hardware tab and set to lowest setting.
