Inventor General Discussion
Active Member
best_industry
Message 1 of 4 (193 Views)
Stress Analysis
193 Views, 3 Replies
01-30-2013 12:45 AM
Hi!
I'm currently doing a project and it involves the use of a flat rectangular plate/beam. Dimension approximately about 100mm by 10mm by 2mm. A constant load will be applied on the end of the surface. I would like to find out if there is a way to find out the maximum number of times i can apply the load (after applying the load, it will be removed and applied on the same point again) to the beam until it fails? I would also like to know if i can apply mulitple loads, at different internal and achieve this too?
Thank you!
You will need some othe product - perhaps Autodesk Simulation.
You cannot do this analysis in Autodesk Inventor.
JDMather
Message 2 of 4 (173 Views)
Re: Stress Analysis
01-30-2013 04:09 AM in reply to: best_industry
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
best_industry
Message 3 of 4 (150 Views)
Re: Stress Analysis
01-30-2013 10:47 AM in reply to: JDMather
Thank you for the response JDMather
Which simulation software will allow me to find out fatigue failure? Autodesk Simulation 360 or Autodesk Simulation Multiphysics?
JDMather
Message 4 of 4 (145 Views)
Re: Stress Analysis
01-30-2013 11:15 AM in reply to: best_industry
You should probably post your question over here
http://forums.autodesk.com/t5/Autodesk-Simulation-Mechanical/bd-p/396
