I was using the stress analysis in Autodesk Inventor 2014. The stress analysis is used on 3 different baseplates (sheet metal parts). When
I change the thickness at "Sheet Metal Defaults" the stress analysis simulation doesn't change it's displacement while the displacement
should differ when changing the thickness. Also Inventor asked for avvvxra5d.fres when opening any baseplate. I linked this file to the
.fres file of the stress analysis in the folder: /AIP/FEA, also don't know if that was something good or bad to do cause it didn't work
for my problem. Can someone please tell me why the displacement doesn't change and what the file is Inventor is asking for. Also at 2 of
the 3 baseplate it still askes for the file and 1 baseplate doesn'te, while I linked all the 3 to there own .fres file.
yes, the plate thickness did change. I will first check if the update button will work. And I will put all my files with the project file on my computer. Cause I worked from my dropbox folder. Maybe that could be a problem. Thanks for replying.
Found the problem. Cause the file was opened from dropbox, the project file in dropbox didn't update and the stress analysis took the settings of the project file (I think).
