Inventor Forum
Stress analysis on wood material
6 REPLIES 6
Ehsancad
3304 Views, 6 Replies
Hello
My name is Ehsan,
I am working as Application Engineer in Egypt.
Some Customers asking if Autodesk Invenor Pro. 2010 can apply stress analysis using FEA on Wood materials.
I can add new material by style editor, but the problem is Wood is orthotropic material, which means the mechanical properties change in the three directions (Longitudinal , Radial & Tangential).
How can we solve this problem in Inventor ?
6 REPLIES 6
henderh
in reply to: Ehsancad
Hi Ehsan,
Unfortunately, R2010 Stress Analysis (and previous versions) can only use isotropic materials. In our material library, we have Young's Modulus and Poisson's ratio with magnitude only, not components.
I've logged wish list item 1247832 in hopes to address this in a future release of AIP.
Currently, Autodesk Algor can handle this type of simulation.
We appreciate you bringing this to our attention. Please let us know if you have any additional questions, comments or suggestions.
Best regards,
Hugh Henderson (Autodesk)
Inventor Simulation SQA Engineer
Hugh Henderson
QA Engineer (Fusion Simulation)
Ehsancad
Thank you very much,but...
what is "wish list item 1247832 "??
henderh
Hi Ehsan,
Wish lists are logged into our tracking system, and they are given a ID number.
If Inventor doesn't have a feature or functionality that a user would like to have, we can request this as a wishlist item to consider adding in a future release of Inventor.
Thanks, -Hugh
Hugh Henderson
scottmoyse
There is a fairly large wood industry out there, and since wood is regarded as a sustainable material, it is being used more and more frequently as a building and engineering material. Going back to our roots i suppose, people will have to relearn how to use timber in the correct ways etc.. and use with more modern methods too. Considering Autodesk is on a sustainable future crusade (which is great) i think it would be a great idea for you guys to implement some timber product specific accelerators and features within inventor (much like you have with the plastic features), Topsolid have a wood module which right off the bat was a seriously productive add on for those using timber based products.
Not to mention it would come in handy for us. Since we design and manufacture super yacht and luxury interiors and inventor plays a major role in our company, having the ability to mix and match all forms of materials in our design and gain productivity from design accelerators in all of those areas would be truly stunning and turn Inventor into a gigacad package.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Ehsancad
Thanks guys,
we asked many People about this issue (Applying FEA on wood material),we can solve this by using Autodesk Algor,or using Autodesk Robot Structure 2010 for this problem......
I think Autodesk Algor accept the Mechanical properties of materials like Autodesk Inventor (Young's modulus,Poisson's ratio,Ultimate strength,etc)...which version of Algor can do this?!!! and how??
and finally,Can Autodesk Robot Structure 2010 do this???!!!!!!!!
henderh
Hi Ehsan,
The attached doc is taken from an Autodesk discussion where Robert Sinfort detailed Inventor Frame Generator + Robobat + Autodesk Expert. I hope you may find it useful. We can utilize Eurocode5 materials definition (for instance)
Best regards, -Hugh
Hugh Henderson
