Show only
Search instead for
Say you are inputing force loads and you select two parallel that arn't connected and type in a force magnitude of 500. If the 500 split between those faces and each face reiceves 250 or do both faces recieve 500?
The force will be distributed proportional to the total area on which it acts. In your case, if both faces have the same area then both faces will have 250, not 500.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
If you are not sure - it should be trivially simple to set up a test problem. As you get into analysis verify everything.
----------------------------------------------------------------------------------------- Autodesk Inventor 2019 Certified Professional Autodesk AutoCAD 2013 Certified Professional Certified SolidWorks Professional
