I have a Aluminum plate of 1200 x 1200 x 25mm thick. I want to find out that how much Max Load it can widthstand.
Is there any possibilty to find out thro' Stress Analysis .
When the following assumptions are true, a solution is available to get you there quickly.
Assumptions:
Solution:
Multiply the current load magnitude by resulting minimum Safety Factor. The new results should bring the minimum safety factor to 1, the yield limit.
I hope that helps, please let me know if you have any questions.
