I deleted the SA inputs from the file while in SA, turned off OLE, deleted the folder and files created by SA.
The 3rd party still shows up and is grayed out when trying to check it into vault. Can't delete it. When trying to the check in the file to vault, the link to the 3rd party file still exists. The doesn't exist on the disk causing a failure to check it in to vault.
How do you get rid of the stress analysis related files, references, and OLE from a file to allow check in to vault?
How to prevent this in the future?
Solved by phila. Go to Solution.
Thanks for the reply. You pointed me in the right direction.
Not sure where/what link manager is. Never had to use it. Search mentions design assistant. Are they one and the same? If so, It shows the links but when I highlight them, it gives an error that the files could not be found and won't allow deletion.
Furthur search found this in the help files Tried it and broke the link and deleted it allowing Vault check in.
You can break the links to OLE-linked documents in models and drawings using the Document Links and Embeddings dialog box. This dialog box also lists any objects embedded within the file.
