HI
How to make a stress analyses for this part.
I place a load 100kg. at the top
It is manly how to place the constrains, I fasten this with 4 M16skrues, see the holes.
How to do this.
Regards
Henrik
Solved by blair. Go to Solution.
By no means should you take my idea as the best solution; however, this is how I would perform the analysis on your bracket....
1.Create circles on the back of the plate around the holes. The diameter of the circles should be the same size as the screw head.
2. Use the split tool and spit all 4 circles so that you end up with circular sections around the screw holes. This would simulate the bolt holding the bracket in place.
3. Next in your simulation, fix the faces around the screw holes, apply your desred load and simulate.
I hope someone who is better suited for this can chime in.
To add to this, I would use a the Vector constrain option for the fixed constraint in the X direction and apply Piinned constraints inside the fastner holes.
Remember to add Gravity and the correct direction (Apple) icon and select the correct direction
The load will be placed across the whole upper surface with uniform loading.
