Your model didn't have any material applied, but I had no problems applying
constraints or a load, it meshed and the FEA checker wouldn't allow analysis
until a material had been applied.
Possibly check your FEA process, working from LH to RH in the FEA
enviroment
1.) Manage - select your type of FEA Analysis
2.) Material -
3.) Constraint(s)
4.) Load(s)
5.) Contacts if required (not in this case)
5.) Prepare (mesh your model)
6.) Solve
IV2011-Pro Suite
Win7-64 Pro
Dell Precission 690, 8Gb, SAS-15k
Quadro FX3500 - 197.59
SpaceExplorer - 3.10.1 / 6.10.0
"shreyas5" wrote in message news:6401049@discussion.autodesk.com...
> I was working on a table for a school project in Autodesk Inventor 2010
> and it needs to be able to support a certain weight. When I go to Stress
> Analysis, I cannot add any fixed constraints or apply force to anywhere on
> the table because the options are not available for reasons unknown to me.
> Does anybody know how I can fix this? The Table is made of ABS Plastic. I
> tried the Stress Analysis before shelling it and it didn't work and it
> still didn't work after shelling it. Is there a problem with the material
> I chose or the way it is built? The Table has a top with a 1yard diameter
> and a circular base which narrows as it reaches the top of the table. The
> narrowest part of the support is 1 foot. Please give me a solution to my
> problem. Thank you for your time, I greatly appreciate it.
