Dear All,
I am facing problem in creating part in top down assly.
Find attachment.
I first part as pipe having dim 300 mm.In assly I select create option and made sketch having diameter 100 circle . I have extrude this circle up to the wall of 1 st component . I select to option but surface of 1 st component not getting selected.
If I select 1 st part rectangular shape, that case 2 part extrude using same concept. (# ref 2 attachment)
Pls help.
Thanks and Regards,
Datta Indalkar
With Warm Regards,
Datta Indalkar.
Solved by maulik_patel. Go to Solution.
Solved by JDMather. Go to Solution.
I'm not sure what you're trying to do. Attach your parts.
Dear mrattray,
Thanks for showing interest in problem.
1. I have created a part naming cylinder. I am in assly mode.
2. I have to create another part naming hollow cylinder.( attachment no-1) I select create option for the same.
3. For that I create a plane 500 mm offset from main plain and I entered in sketch for hollow cylinder. (# attachment no-3).
4. I made sketch on selected plain.( # Attachment No-2)
5. I said finish sketch.
6. Now I have to extrude this hollow cylinder to up to my part no 1 that is Cylinder. So I select extends ' TO '. Then I am trying to select Cylinder's surface as reference But the surface is not getting selected. ( find attachment no 3)
So I am unable to extrude this hollow cylinder up to main cylinder.
( The 1 st part is shell of pressure vessel and hollow part is nozzle pipe on the pressure vessel shell. )
I hope you will understand what I have make. Pls help me.
Thanks and Regards,
Datta Indalkar
This is not a strange problem - done all the time.
http://forums.autodesk.com/t5/Autodesk-Inventor/Strange-problem/td-p/3511308
Hello Datta,
Firstly I am going to explain you, why Inventor is behaving like this.
I have a workaround for you in this case. Follow below mentioned steps:
Let me know if more help is need
Thank you,
Maulik Patel
Dear Sir,
Thank you very much for your kind replay.
It is working.
Like this problem I have one more problem naming finish sketch by my name if you could answer that question I will be very obliged.
Thanks and Regards,
Datta Indalkar.
Click twice slowly on the sketch name. You can now edit it. (sometimes click F2 works, but I simply slow double click)
Dear sir,
I not getting what you have to say.
Will you pls explain with some images?
I want overall size of part in bom ( 200 x 100 x 20 ). ( # ref attachment)
I am not intrested writting those value in iproperties.
Software itself should choose overall size of part and put into the part list.
Will it be possible by customization of software ?
Thanks and Regards,
Datta indalkar
Hello Datta,
Can you send me details for that? My email address is maulikr.patel@autodesk.com
Thannk you,
Maulik Patel
