No the PCs are not all the same. The only common thing is they are all
Compaq PCs running W2K SP3, Autodesk AIS and Microsoft Office 2K (the
version with Access, it si the Business or Professional whatever it is) They
all have 512MB RAM or more. The two with the weird behavior have NVIDIA
Quadro2 MXR or Quadro4 700 XGL on them two different drivers. I have another
PC just like the one with the Quadro2 MXR same driver same everything but it
does not have the behavior. I probably should go test the other 14 PCs to
see if they do this.
On one PC I have uninstalled all of the AIS apps deleted the folders cleaned
the registry rebooted the PC turned off the Anti-virus software and
reinstalled no change in behavior.
"AUGUST PANNING"
wrote in message
news:B1D11E2636D028E0D450FFFA47985D62@in.WebX.maYIadrTaRb...
> Are all the PC's EXACTLY the same and what are the general specs on them?
> I've never seen this problem, it is wierd.
> "Jack Gates" wrote in message
> news:DFD6008C812441A113F1344D20A00F93@in.WebX.maYIadrTaRb...
> > I have two PCs doing this strange behavior. I have checked 7 of the 21
PCs
> > and got 2 to behave this way.
> > Create a part or assembly file with something in it. Save it start an
IDW.
> > Switch back to the IPT or IAM and change the camera from ORTHOGRAPHIC to
> > PERSPECTIVE. Switch back to the IDW and the whole sheet is skewed. This
> > happens if I put views in the IDW or not. This happens every time I
switch
> > the IPT or IAM from ORTHOGRAPHIC to PERSPECTIVE camera and then switch
> back
> > to the IDW. When the IDW is saved, closed and reopened then it is fine
> until
> > I do the above procedure again. Autodesk has not been able to reproduce
> this
> > problem. The file does not get corrupted. This appears to be a very
wierd
> > graphics issue.
> > Has anyone seen this before? Would everyone try this and report back if
> you
> > see this behavoir and share your hardware/software specs?
> > Thanks to all who give feedback on this,
> > Jack
