Inventor Forum
STP FILE SHEETMETAL FLAT PATTERN
6 REPLIES 6
mariappan.u
1157 Views, 6 Replies
Hi all,
I have stp file to convert sheetmetal flat pattern.i can convert some portion but i cant convert particular portions.
see attached file.
waitng for solution.
6 REPLIES 6
JDMather
in reply to: mariappan.u
You might be waiting a while - of course Inventor will not unfold a jpg image.
You will need to attach the ipt file here.
mariappan.u
in reply to: JDMather
I CANT ATTACH STP FILE IN THIS FORUM
JDMather
Right click on the file name and select Send to Compressed (zipped) Folder
and attach the resulting *.zip file here
or
attach the translated *.ipt file here.
mariappan.u
here is the attachment.
JDMather
If you look in this area from the right side this face (and I assume the opposite face) is warped.
This was hard to see from the jpg you originally posted.
You will have to Delete Face and rebuild that area of the part.
JDMather
Considering manufacturing tolerance - perhaps this is close enough.
