Inventor General Discussion
Active Member
0 Kudos
Post 1 of 7
STP FILE SHEETMETAL FLAT PATTERN
522 Views, 6 Replies
12-06-2011 02:32 AM
Hi all,
I have stp file to convert sheetmetal flat pattern.i can convert some portion but i cant convert particular portions.
see attached file.
waitng for solution.
2,122 Kudos
Post 2 of 7
Re: STP FILE SHEETMETAL FLAT PATTERN
12-06-2011 04:43 AM in reply to: mariappan.u
You might be waiting a while - of course Inventor will not unfold a jpg image.
You will need to attach the ipt file here.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
0 Kudos
Post 3 of 7
12-06-2011 08:00 PM in reply to: JDMather
I CANT ATTACH STP FILE IN THIS FORUM
2,122 Kudos
Post 4 of 7
12-07-2011 04:09 AM in reply to: mariappan.u
Right click on the file name and select Send to Compressed (zipped) Folder
and attach the resulting *.zip file here
or
attach the translated *.ipt file here.
Active Member
0 Kudos
Post 5 of 7
12-08-2011 05:20 PM in reply to: mariappan.u
here is the attachment.
2,122 Kudos
Post 6 of 7
12-09-2011 05:05 AM in reply to: mariappan.u
If you look in this area from the right side this face (and I assume the opposite face) is warped.
This was hard to see from the jpg you originally posted.
You will have to Delete Face and rebuild that area of the part.
2,122 Kudos
Post 7 of 7
12-09-2011 06:56 AM in reply to: JDMather
Considering manufacturing tolerance - perhaps this is close enough.
