Inventor Forum
Stop sketch drawing rotation
3 REPLIES 3
NachitoMax
684 Views, 3 Replies
this is really annoying me 🙂 every time a select a plane to sketch onto, it rotates 180 degrees...... i have looked in the settings but cannot really find anything.. i have attached images for reference 🙂
nigel
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
3 REPLIES 3
Cadmanto
in reply to: NachitoMax
Nigel,
That is why I created this idea.  Feel free to cast your kudo support for it.
http://forums.autodesk.com/t5/Inventor-IdeaStation/Prevention-of-New-Sketch-from-Rotating-180/idi-p/...
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
yannicknielsen
Since there is already a post about that, I'll come with my thoughts on another way to avoid the annoyance 🙂
Personally I find the fact that it wants to look on the plane very annoying, so I just disabled that feature.
Now when I create a sketch, it doesn't move one bit.
You can find that option under Options > Sketch > Disable "Look at sketch plane on sketch creation"
Product Design Suite Ultimate 2021
Cadmanto
in reply to: yannicknielsen
I know personally I would rather look at the sketch face on and spin it if I really need to.  When it does rotate, I do end up spining it around where I want it.  Semi easy to do.
Best Regards,
Scott McFadden
