I am trying to turn on the stock number field under customizable fields within vault, however stock number is not an option...has this always been the case?
Thanks for your time,
This is another one that should be in the Vault forum. http://forums.autodesk.com/t5/Autodesk-Vault/bd-p/101
What version of Vault are you using,... what version of Inventor?
Stock Number in Vault is not a System Property. It is a User Defined Property, even though it correlates to an iproperty. This is actually true of a lot of iproperties. You will have to create this property in your Vault, and map it to the file property depending on what end result you are after.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
