Inventor General Discussion
Member
czoobs
Message 1 of 15 (1,557 Views)
STL - can I export only surfaces?
1557 Views, 14 Replies
08-06-2010 11:39 AM
Hello Inventor users,
I'm wondering if there is a possiblity in Inventor to export a surface model as a STL file. I use CAD programs to prepare models for simulations in other software and I would like to work with Inventor because my Depratment uses it. Till now I have been using SolidWorks and with a little trick it is possible to export surfaces as a STL file. In Inventor I didn't manage to do this. So, is it possible?
Best regards,
Wojek
Valued Mentor
jclaidler
Message 2 of 15 (1,554 Views)
Re: STL - can I export only surfaces?
08-06-2010 11:51 AM in reply to: czoobs
STL is an export option for Inventor 2011.
_______________________________________________________________
ITO - Application Management
AutoCAD 2014 | Inventor Professional 2014 | Vault Professional 2014
JDMather
Message 3 of 15 (1,543 Views)
08-06-2010 12:42 PM in reply to: czoobs
 Wojek
I don't think it is possible to export surface bodies as stl in Inventor.
AFAIK only solid bodies are supported for stl export.
(Of course the exported stl is all surfaces as stl is a surface definition format.)
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Employee
AustinLiu
Message 4 of 15 (1,520 Views)
08-08-2010 07:40 PM in reply to: czoobs
Wojek,
It's not feasible for Inventor to export surface data as STL.
Why not use other formats instead? IGES/STEP/Parasolid?
Also if available, please share me more information about your workflow and request. We may consider the surface export in STL later.
Austin
Austin-Zongjie Liu
Zongjie.Liu@autodesk.com
Software Quality Assurance Manager
Design, Lifecycle & Simulation
Member
czoobs
Message 5 of 15 (1,500 Views)
08-09-2010 07:52 AM in reply to: czoobs
Thank you for your answers.
As I mentioned before I use CAD programs to prepare models for my simulations. To be precise, I simulate work of bulk handling machines and devices with the Discrete Element Method. In these simulations it is advisable to use simplified geometry because of the character of the calculating process. In many cases I need only one side of, for exemple chute wall, and surface is far enough. For now I can only import STL geometry and that is why I asked about this format.
I would like to use Inventor because my department uses it and there wouldn't be any problems with data exchange.
Distinguished Mentor
rdyson
Message 6 of 15 (1,494 Views)
08-09-2010 08:56 AM in reply to: czoobs
Buy a seat of Rhino 3D, about $1000
Export from IV to Rhino as stp
Save as stl in Rhino
JD,
FYI, stl is polygon mesh, not surfaces
Member
czoobs
Message 7 of 15 (1,482 Views)
08-09-2010 10:09 AM in reply to: czoobs
Yes I know what STL is :smileywink:
The way you suggested...this is not a good solution. Maybe I'll just stay with SolidWorks
Valued Mentor
jclaidler
Message 8 of 15 (1,480 Views)
08-09-2010 10:11 AM in reply to: czoobs
Try creating a 'level of detail' that only has surfaces, then export as an STL.
JDMather
Message 9 of 15 (1,475 Views)
08-09-2010 10:45 AM in reply to: jclaidler
Can you attach example files of this workflow?
New Member
grv19191
Message 10 of 15 (1,076 Views)
07-15-2011 12:59 AM in reply to: czoobs
I am having problems with saving some surfaces as STL in solidworks. Please help me with how can i save as stl in solidworks.
