I've seen questions in the past regarding the creation of binary STL files.
Inventor only creates ASCII STL files. (Don't ask me why because I don't
know.) For those of you that need binary files I've created a small
converter utility. The executable is attached along with the source code,
if you're interested in how it was written. It was written using VB Express
2005. This is a free version of Visual Basic.
To use the converter, just run ConvertSTL.exe. A dialog will be displayed
where you can pick the existing ASCII STL file and specify the filename of
the binary file. It's also possible to use this in a more automated way
since is supports command line arguments. The first argument is the ASCII
STL filename and the second argument is the binary STL filename.
Brian Ekins
Autodesk Inventor API
