Inventor Forum
Stiffener Ribs
7 REPLIES 7
Message 1 of 8
1632 Views, 7 Replies
Stiffener Ribs
Help! Can anyone tell me how to add stiffening ribs
to sheet metal parts?
Thanks, Joseph
7 REPLIES 7
Message 2 of 8
you could make a weldment, and add them there. or just make a workplane in the center of your part, just offset from the material thickness (so it's in the middle, if that's where you want it), and the do a face extrude. if you do this though, it will not show up in the flat pattern. did i answer you question? -Joe
Message 3 of 8
There is a formed rib iFeature on the cbliss.com site. It is about 3/4 of
the way down the page.
http://www.cbliss.com/inventor/Parts.htm
Hal Gwin
Mechanical Designer
Xenogen
"Joseph Shelton" wrote in message
news:f14351e.-1@WebX.maYIadrTaRb...
> Thanks, Joseph
Message 4 of 8
Almost, I'm not sure how to get this to work over a
90 deg. bend though.
Thanks,  Joseph
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
you
question? -Joe
Message 5 of 8
Thanks, I will check it out.
Joseph
"Hal Gwin" wrote in message
news:3911B2639540A057A5362425B01C0F3D@in.WebX.maYIadrTaRb...
> Hal Gwin
> Mechanical Designer
> Xenogen
> > Thanks, Joseph
Message 6 of 8
And be sure to read the instructions provided. It is most assuredly one of
the hardest iFeatures to place and control the first few times you try using
it. It has been a very useful addition to my sheetmetal tool library
however now that I have learned to use it.
Hal Gwin
Mechanical Designer
Xenogen
Message 7 of 8
Hi again, I tried this however I guess I just don't know what I am
doing. It will only let me pick one plane and it rotates the rib 90 deg.
to plane I want.
Thanks, Joe
> Hal Gwin
> Mechanical Designer
> Xenogen
> > Thanks, Joseph
Message 8 of 8
news:682767B9C6A86707E32B0083B711588A@in.WebX.maYIadrTaRb...
> to plane I want.
> Thanks, Joe
Reread the instructions. You can control the angle at insertion or later
with a dialog box. It takes some experimentation to recognize what exactly
the instruction are referring to. Keep trying, once you get the hang of it,
it is really not as difficult to use as it seems.
Hal Gwin
Mechanical Designer
Xenogen
