Dear Mates!
I have THIS 50MB of crap. I'd like to convert it to something more usable solid. I only need its outer shape. I've tried derive but there's nothing in the list to derive. Trying to patch, sculpt or any else will result Inventor to crash. Please help!
I use Inventor 2011 so I'd need V2011 ipt or STP / SAT.
Thanks in advance!
Solved by WHolzwarth. Go to Solution.
Zoltan,
Where did you get this file? Any chance you can get the file in a different format that gives you a better start?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
It was given by our customer. I have Pro/E, IGES, Parasolid and SolidWorks versions of this device, but I couldn't even open half of them, the rest is just the same as this STEP just their filesize changes. For example, IGES version is 70MB but still contains 2890 surfaces.
michaeldavis: I don't know if they made any translations. I've tried to stitch but ended in a meaningless result.
Anyway, thanks for trying help both of you.
BTW I've updated my rig. Even this machine has difficulties with this mess and I have a few more device so I don't even know what to do. Communicating with our customer is not a problem, but first of all, I have to know if I can handle these files or not. I thought my knowledge is low, but it seems these files are really useless.
@Zoltan78 wrote:
...I have Pro/E, and SolidWorks versions of this device...
Are either of these native files?
Zip and attach here.
You can get some solids back from this Step, but this is a time-consuming task. I took a closer look and saw many missing faces. Well, there are tricks to re-create them, but that's no matter of only a few minutes. Each and every face set needs to be looked at separately.
Walter
Walter Holzwarth
SolidWorks - same surface horror
IGES - Inventor crashes
Parasolid - seems forever to be opened, so I cancelled (had to kill Inventor's task)
Pro/E - error in htm format: Translation failed. Invalid File Type. I guess the file is a newer version.
Anyway, I've uploaded all format that I have HERE. Hovewer, bothering you or someone else with every single file is not an option in the long run, so I have contacted with our customer.
UPDATE: got response from our customer: these files are directly from the manufacturer. I'm wondering.
JDMather: I can't determine if they are native files or not, so it's up to you 🙂
wh: yeah, I could fix them if I had all the time in the world. I have drawings & data sheets, too, so re-drawing them in Inventor would be less waste of time.
My Inventor is quite up to date, but I guess it doesn't help. I'll give a shot to Inventor 2014 Trial.
I bet, Inventor 2015 will be out soon, so there's no reason to purchase (upgrade to) version 2014 even if my company wanted to. Even much if V2014 still can't do anything with these files.
I will not go to a third party file sharing site to download.
Zip and attach the *.sldprt file here or at Autodesk360.
The source should be able to tell you what software the geometry was modeled in.
@Zoltan78 wrote:
I bet, Inventor 2015 will be out soon, .....V2014 still can't do anything with these files.
I doubt there will be an Easy Button in 2015 that magically conjures up missing geometry.
I've opened the x_t version with 2014. It took some time, but in the end I got an IAM with 2902 surface members. I've looked at the first member and found only some faces, not enough for a solid.
😉 But there are some tricks available for getting the solid back. See sample.
Walter Holzwarth
I've looked deeper into the import. It's always the same: Multibody SLDPRTs have lots of tiny faces missing, and naturally that's the same with files, that have been exported from this basic file.
I've brought some parts back to solid life again, but it's time-consuming. See attachments.
Zoltan, go to your customer, ask them to open the SLDASM of this machine, and derive a STEP or Parasolid (better IMO) from that SLDASM. After that, you shouldn't have to struggle with missing faces furthermore.
Walter
Walter Holzwarth
Thank you for your efforts. I'll try to get a proper model.
JDMather: I've tried to upload here but it says: "The contents of the attachment doesn't match its file type.". And that's why I don't use that rudimentary, ridiculous, progress-indicator-free trash instead of trustful 3rd party up-to-date file sharing services.
Zoltan,
If it helps I have access to Solidworks 2011 and Inventor 2014. I can try looking at this file and see if I see anything.
Would you be able to email it to me? Or have you uploaded it to Autodesk 360?
