Inventor Forum
STEP files: Inventor 2013 vs Inventor 2014
30 REPLIES 30
Message 1 of 31
nbatchelder
5802 Views, 30 Replies
Does anyone know if there is a difference between STEP files generated in Inventor 2013 and Inventor 2014?
Typical workflow: Open Assembly > I > Export > CAD Format > STEP
I recently transitioned from 2013 to 2014 and have not encountered any issues with the software untill now.  I am making STEP files of assemblies and importing them into CAM software, but the Inventor 2014 STEP files (of assemblies, not single parts) are causing crashes.  Single part STEP files cannot be batch imported into our CAM software, hence the need for STEP files of assemblies.
2013 & 2014 single part STEP files work fine.
2013 assembly STEP files work fine.
2014 assembly STEP files cause a crash.
Probably,
Niles
30 REPLIES 30
Message 21 of 31
evelynyin
in reply to: ak_staib
Hi ak_staib and VirgilGhizelea, Thank you for reporting this issue. I can reproduce this issue on QuickStep2010. Since the STEP file can be opened in SWX, PRO/E and NX correctly, it would be complex to find where the problem is. However, the file have been send to develop team for further investegation. Will update to you if there is any feedbacks. For Inventor 2012, it can be opened as RayFeiler shows. Have you made any changes to your templates or path to templates in your current Project. It looks more like a template issue than a translation issue to me. You can check the template settings in "Tools -> Application Options -> File" or "Project -> Project Name -> Folder Options" Thanks, Evelyn
Evelyn Yin
Yiyun.Yin@autodesk.com
Software Quality Assurance
Manufacturing Product Group
Autodesk, Inc.
Message 22 of 31
ak_staib
in reply to: evelynyin
Yes. The templates was changed somehow to the 2014 folder. Importing with the 2012 Templates is working now.
But Still can't open it with STP Viewer or Quickstep
Thank you
Message 23 of 31
evelynyin
Yes, we noticed the QuickStep 2010 failed to open the step file. Will update to you if there is any progress. Thanks, Evelyn
Evelyn Yin
Autodesk, Inc.
Tags (3)
Message 24 of 31
dev
I'm fencing the same problem (with STP Viewer). Any news / update about this subject ?
I have seen that SP1 for Inventor 2015 fixes the problem. Maybe the problem is solved for version 2014 as well ?!
Thanks in advance for your response.
Colin
Message 25 of 31
Mirko_Opitz
in reply to: nbatchelder
Hello there
We have the same problem with assemblies exported to STEP files from Inventor 2014 (SP2). Altium Designer can't open those STEP files.
STEP files from parts can be imported.
It seems there is a new export module in 2014?!
Message 26 of 31
evelynyin
in reply to: dev
Hi Colin and MirKo,
We are really sorry for the inconvenience that brings. This defect has been fixed in Inventor 2015 SP1. This issue hasn't been fixed in Inventor 2014 yet. But it will in the near future.
You can send your files if you need: Yiyun.yin@autodesk.com
Evelyn
Evelyn Yin
Autodesk, Inc.
Message 27 of 31
dev
Hi Evelyn,
Thanks for the feeback !
Any idea about when should that be fixed ? End of the year ? Next year ?
This issue is a big problem...
Message 28 of 31
evelynyin
in reply to: dev
Hi Colin,
We understand the inconvenience that brings and will keep you update once the fix is released.  If you need any help before release you can contact me directly.
Evelyn
Evelyn Yin
Autodesk, Inc.
Message 29 of 31
KevinLi-Autodesk
in reply to: dev
The fix also available in Inventor 2014 SP2 Update3, please download and install it via http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/update-3-fo... and have a try.
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 30 of 31
ak_staib
in reply to: KevinLi-Autodesk
Export to STEP is working now. Thanks
Message 31 of 31
dev
Thank you, I??ll try it !
Meilleures salutations
Colin Dellea
D??veloppeur
HURNI ?M
ENGINEERING
Newsletter : Inscrivez-vous ?? info@hurni.ch pour recevoir les derni??res informations techniques, g??n??rales, formations, promotions, et invitations.
Autodesk Gold Partner
________________________________
Chemin de la Combeta 3 ?M CH-2300 La Chaux-de-Fonds ?M www.hurni.ch
Administration et ventes +41 32 924 50 90 ?M info@hurni.ch
Service technique +41 32 924 50 92 ?M support@hurni.ch
Suivez-nous sur les r??seaux sociaux
Facebook LinkedIn Blog
