Does anyone know if there is a difference between STEP files generated in Inventor 2013 and Inventor 2014?
Typical workflow: Open Assembly > I > Export > CAD Format > STEP
I recently transitioned from 2013 to 2014 and have not encountered any issues with the software untill now. I am making STEP files of assemblies and importing them into CAM software, but the Inventor 2014 STEP files (of assemblies, not single parts) are causing crashes. Single part STEP files cannot be batch imported into our CAM software, hence the need for STEP files of assemblies.
2013 & 2014 single part STEP files work fine.
2013 assembly STEP files work fine.
2014 assembly STEP files cause a crash.
Yes. The templates was changed somehow to the 2014 folder. Importing with the 2012 Templates is working now.
But Still can't open it with STP Viewer or Quickstep
Thank you
I'm fencing the same problem (with STP Viewer). Any news / update about this subject ?
I have seen that SP1 for Inventor 2015 fixes the problem. Maybe the problem is solved for version 2014 as well ?!
Thanks in advance for your response.
Colin
Hello there
We have the same problem with assemblies exported to STEP files from Inventor 2014 (SP2). Altium Designer can't open those STEP files.
STEP files from parts can be imported.
It seems there is a new export module in 2014?!
Hi Colin and MirKo,
We are really sorry for the inconvenience that brings. This defect has been fixed in Inventor 2015 SP1. This issue hasn't been fixed in Inventor 2014 yet. But it will in the near future.
You can send your files if you need: Yiyun.yin@autodesk.com
Evelyn
Hi Evelyn,
Thanks for the feeback !
Any idea about when should that be fixed ? End of the year ? Next year ?
This issue is a big problem...
Hi Colin,
We understand the inconvenience that brings and will keep you update once the fix is released. If you need any help before release you can contact me directly.
Evelyn
The fix also available in Inventor 2014 SP2 Update3, please download and install it via http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/update-3-fo... and have a try.
