Inventor Forum
Steel, Galvanzied appearance is not galvanized...
2 REPLIES 2
jyager
2424 Views, 2 Replies
Inv '14...when I create a SM part, with the material as "Steel, Galvanized" the default appearance is "Galvanized"...this is just a flat gray color. However, I can go into appearances and change it from it's default "Galvanized" to "Steel Galvanized"...and then it looks correct.
Am I missing something here?
Jason Yager
Inventor Professional 2023.2
Windows 10 Pro 21H2
Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
32GB RAM
AMD Radeon Pro WX 3200 Series
3D Connexion SpaceMouse Pro
2 REPLIES 2
in reply to: jyager
I'm new to Inventor, but I think that the "Steel, Galvanized" Material is for actual hot-dip galvanized steel. If you do a rendered picture of the model, the details of the "Galvanized" Appearance pop out.
I also think the "Steel, Galvanized" Appearance is supposed to mimic actual sheet steel or electro-plated steel. Although, it tends to look more chrome-like in a rendered picture.
I wish there were more "sub-categories" of materials (and their corresponding appearances) by default. It sure would be nice to say "I'm building a cart with a box tubing frame made of Aluminum 6061-T6 and the sheet metal parts are made from Aluminum 5052-H32..." and then just select the corresponding material. Granted, I know there are a lot of materials out there and metal isn't the only one, but a nice user-maintained open-source central material database would be a nice touch.
4donwan4
in reply to: jyager
You have the ability to modify and create templates, material files, and design data information as you desire. Why we have certain things set as default is not something I can really comment on, those default settings are just for generalization. I would just make those changes within the materials file will create a specific one for your needs.
Don
