Our appearances for Carbon steel and a few of the stainless steel appearances such as 310 and 317 were accidentally changed in our libraries. So now we are caught in an "update" loop. If we update and save our appearance in the Inventor library it then wants to change it in the Autodesk library and vice versa. Could anyone tell me what the default appearance of Steel, Carbon in the Inventor library and Stainless Steel AISI 310 in the AutoDesk material library?
Solved by Cadmanto. Go to Solution.
What version of Inventor?
15 we are on subscription.
Tim,
This is from 2013, but should be the same as 2015.
Other then this, you could always reload the CC.
Hope this helps you.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Does anyone know if there is a way to force the styles from whatever the top level is down?
Is there a way to synchronise them all at once?
I want to take what it is, where it came from, and what it's checking against and make them all the same.
My Standard.iam template has three colors: Aluminum - Flat, Silver, and Titanium that differ from the definitions in the style library. I think I used the Aluminum color in a part once, but I don't mess around like that in the assembly. Plus I don't think anyone else here knows how to even get to where you could change the colors. Somehow they got changed, it'd be nice if there was one button to change them back.
