Inventor Forum
Startup issue and no materials in library
3 REPLIES 3
shuaib_cad
395 Views, 3 Replies
I have startup issue with inventor 2012 and the material library is empty.
I some how deleted the inventor folder in documents. I again copied the folder from my friends system but didn't work.
Please look at the attachments and advice...!!!
Regards
K. Mohammed Shuaib
3 REPLIES 3
Cadmanto
in reply to: shuaib_cad
Honestly, I would reload the software to get the libraries back the way they should be.  You don't even need to uninstall your currect version unless you trully feel it is that messed up.  Then once you get everything back, don't copy from where you got them before again.  Not a good idea!!!
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
shuaib_cad
in reply to: Cadmanto
Thanks for your quick response!!!
I can not uninstall the software myself unless i get the permission from the IT department.
Can you please give me a solution to get back the material library atleast?
Regards
K. Mohammed Shuaib
Cadmanto
Take a look at this link.
http://docs.autodesk.com/INSTALL_LICENSE/2014/ENU/Autodesk%20Installation%20Help/index.html?url=file...
Best Regards,
Scott McFadden
