Inventor General Discussion
Active Contributor
shuaib_cad
Message 1 of 4 (208 Views)
Startup issue and no materials in library
208 Views, 3 Replies
01-19-2014 05:51 PM
I have startup issue with inventor 2012 and the material library is empty.
I some how deleted the inventor folder in documents. I again copied the folder from my friends system but didn't work.
Please look at the attachments and advice...!!!
Regards
K. Mohammed Shuaib
Take a look at this link.
http://docs.autodesk.com/INSTALL_LICENSE/2014/ENU/Autodesk%20Installation%20Help/index.html?url=files/GUID-3CDDE15C-925D-46A9-9E62-0582A9E8DDBB.htm,topicNumber=d30e18316
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Cadmanto
Message 2 of 4 (189 Views)
Re: Startup issue and no materials in library
01-19-2014 06:25 PM in reply to: shuaib_cad
Honestly, I would reload the software to get the libraries back the way they should be.  You don't even need to uninstall your currect version unless you trully feel it is that messed up.  Then once you get everything back, don't copy from where you got them before again.  Not a good idea!!!
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Active Contributor
shuaib_cad
Message 3 of 4 (180 Views)
01-19-2014 06:39 PM in reply to: Cadmanto
Thanks for your quick response!!!
I can not uninstall the software myself unless i get the permission from the IT department.
Can you please give me a solution to get back the material library atleast?
Regards
K. Mohammed Shuaib
Cadmanto
Message 4 of 4 (176 Views)
01-19-2014 06:52 PM in reply to: shuaib_cad
http://docs.autodesk.com/INSTALL_LICENSE/2014/ENU/Autodesk%20Installation%20Help/index.html?url=file...
Best Regards,
Scott McFadden
