Inventor General Discussion
Distinguished Contributor
eveylynne
Message 1 of 2 (731 Views)
Starting a new sketch
731 Views, 1 Replies
02-02-2012 11:41 AM
How does Inventor decide how to orient the axisis for a new sketch?  Sometimes, when I create a sketch on a face of a feature, the sketch sometimes rotates to an odd angle (Untitled.png).  I can create a sketch on a different, parallel surface and the sketch doesn't go to odd angles.  Why does Inventor do this?  How do I edit the orientation?  I've attached the part that I'm having the issue in.  When I try to create a sketch on the face of the loft, the x/y does things I don't understand. This happens often enough to be very frustrating.  I have work arounds, but I would much rather be able to fix the issue, or prevent it completely.
Yay! Tis [mostly] solved!
eveylynne
Message 2 of 2 (655 Views)
Re: Starting a new sketch
03-30-2012 06:11 AM in reply to: eveylynne
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
