After having installed all the updates, Inventor hangs on startup.
I need to start at least 2 times for Inventor to continue.
Hello Joostroopers,
I´ve been encountering the very same problem recently.
Sometimes I end the process structure via task manager,
afterwards it works in most cases.
I have not kept track of the update history closely, yet as
you mention it - this could most likely the problem.
Kind regards
Daniel
Before we had installed the updates the problem was already there.
We had hoped that it would be solved after installing the updates.
That migh be right...
Yet I can´t remember this happened in the initial release of FDS and it´s Inventor.
Kind regards
Daniel
