Inventor Forum
start folder
19 REPLIES 19
Message 1 of 20
719 Views, 19 Replies
start folder
I've just had IV6 installed and I can't seem to get IV6 to use my projects
folder as my initial startup folder in the open dialog. Instead it keeps
going to a network drive that has tons of files in it. Can this be set
somehow?
19 REPLIES 19
Message 2 of 20
Tools-Application Options-File tab - Projects Folder
HTH
Peer
"Mike" wrote in message
news:A54253DD3B9F519D725E07CC94AA04A1@in.WebX.maYIadrTaRb...
> somehow?
Message 3 of 20
Not sure, maybe this is what you are after:
I have several Desktop shortcuts for IV, each starting IV with another one
of my project files.
Leo Laimer
Bad Ischl - Austria
Message 4 of 20
Yeah, I had that set already. I double checked it and it is correct but
Inventor still goes to the network drive instead.
"Peer Hoffmann" wrote in message
news:AFB9454A4BE42E3DF5E32337BE687D61@in.WebX.maYIadrTaRb...
> HTH
> Peer
projects
keeps
> > somehow?
Message 5 of 20
It defaults to the last one you worked on (the checked one).
HTH
Peer
news:7A69D4E47F911EAA86E96D8C148EED93@in.WebX.maYIadrTaRb...
> > HTH
> > Peer
> projects
> keeps
set
> > > somehow?
Message 6 of 20
I think I may not have been clear at what I am trying to do. I am not
switching project files, I am just trying to get Inventor to start off in my
Workspace folder when I start the open dialog and sofar I've been
unsuccessful.
news:57C3D0E4D0D91B8E34276E961414A78C@in.WebX.maYIadrTaRb...
> HTH
> Peer
> > > HTH
> > > Peer
> > projects
> > keeps
> set
> > > > somehow?
Message 7 of 20
Is the problem with just this one project file or for all project files?
MechMan
Message 8 of 20
All project files.  However, each project file
seems to start in a randomly different folder, none being my
workspace.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Is
files?
MechMan
Message 9 of 20
Thanks Mike. Now you've put your mojo on me. I'm now seeing the same thing. I created a quick project file to only look at the C:\ drive and it's defaulting to look elsewhere. I can fix it by turning off Relative Paths but as soon as I turn Relative Paths back on the Workgroup reverts back to some other diretory.
IV6 SP1
MechMan
Message 10 of 20
Ok Mike, I'm not sure exactly what's going on but if you edit the IPJ file manually via Notepad it seems to fix the bug I created here. Let me know if that works for you.
MechMan
Message 11 of 20
Yea we get that here too. specially if the Locations area of the open dialog is full (needing a scroll to see everything). It seems to scroll to the end and select the directory at the top of the list. So depending on your projects a different directory for each one. Quite annoying and have not found a fix. Neither sp fixed it. - ed -
Message 12 of 20
We use notepad to edit ipj's but if the list in the Locations area is full it does not help, at least here. What about you Mike? - ed -
Message 13 of 20
It seems that there is a limit to the number of
locations you can have under anyone of the subheadings in a project file.
The limit appears to be 12.  If you exceed 12, then Inventor does not start
up in your workspace.
Can anyone confirm?
We
Message 14 of 20
No, can't confirm. My test gave me trouble with just one entry under any heading.
MechMan
Message 15 of 20
I have been working on this problem with my dealer,
and they have a call into autodesk.  They claim that it is the quantity 12
that is the problem but I have not been able to verify that one way or the
other.  I will see if they can provide me with a work around and then post
it here.
No,
heading.
MechMan
Message 16 of 20
Did manually editing the IPJ file via Notepad not work? Did for me.
MechMan
Message 17 of 20
No, that did not work, but thanks.
Did
me.
MechMan
Message 18 of 20
Are you starting by opening IV and selecting the
project there or by double clicking on the IPJ?  I have seen different
behavior based on how you access the project?  You should always do the
former..
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
Did
me.
MechMan
Message 19 of 20
No, I am not double clicking the project.  I
have only one project right now so I am not switching projects.  The
problem is I simply start in the wrong folder when I select the open
dialog.  I tried creating different project files with different numbers of
folders and different arragemnets of folders to see the effect on which folder
the open dialog starts in.  It does change which folder it starts in, but
it still never starts in my workspace unless I reduce the number of folders
listed in the path to just a handful..
former..
Sean Dotson, PE
Check the Inventor
Did
me.
MechMan
Message 20 of 20
This is a bug that has been introduced since r6.
You can not control the the startup folder within your project
workspace. Re-ordering the statements has no affect. IV just uses its
favorite little location with loss of user control to specify.
Kent Mathews
