Thanks for trying Dennis. Just to make sure I'm not crazy I started a new
part in the Standard template with the same results. As soon as I hit Save
it jumped to a Sheet Metal part. It's a head scratcher. Oh yeah, it does not
work the other way. A Sheet Metal part stays a Sheet Metal part.
Bob
"Dennis Jeffrey" wrote in message
news:5975016@discussion.autodesk.com...
Sorry, but I could not duplicate your problem using your template.
Collar2.ipt was created by copy and paste of the features into a new file
created from your template. When I saved it, it remained a standard, not
sheet metal part.
Collar3.ipt was created from scratch using your template. Again, on save,
the remains a standard part.
I also noticed that creating a new part from your template results in
Sketch2 as the initial sketch, creating extrusion2 as your first feature.
Clearly, someone has messed with this template.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
"OBO" wrote in message
news:5974910@discussion.autodesk.com...
Ooooops! Here they are. Thank you for time Dennis.
Bob
"Dennis Jeff
news:5974916@discussion.autodesk.com...
Errors on opening Collar. Please attach the spreadsheet as well.
HP zv5000 AMD64 2GB
htt
p://teknigroup.com
news:5974
849@discussion.autodesk.com...
Here it is. Now remember, I used the Standard ipt. templa
te, and it changed
to Sheet Metal when I hit save.
Bob
news:5974752@discussion.autodesk.com...
Zip and attach your Standard.ipt AND the affected part.
Inst
HP
zv5000 AMD64 2GB
Geforce
http:
//teknigroup.com
news:5974667@discussion.autodesk.com...
Starting with the Standard ipt. template, and at no time swtching from Part
Features to Sheet Metal Features.
Version 2009 (just loaded last Thursday).
Bob
news:5974609@discussion.au
todesk.com...
Are you starting from a sheet metal template, conve
rting to sheet metal
features,
or using a template created from a sheet metal template?
What
version of Inventor?
HP zv5000 AMD64 2GB
"OBO"
wrote in message
news:5974538@discussion.autodesk.com...
When
I go to save a Standard Part the Pan
el Bar morphs from Part Features
into Sheet Metal Features. W
hen the part is inported into an assembly it
comes in as a Sheet Metal Part.
From what I can tell all my settings look okay. I'm tapped.
Bob
