Inventor General Discussion
Active Member
jimdaug
Message 1 of 5 (561 Views)
Standard (mm).ipt default orientation?
561 Views, 4 Replies
12-28-2012 08:51 PM
Probably a dumb question, but why does the standard part (mm) template start with the view cube having the front (XY) plane oriented as the top view when you finish the sketch. In other words, when I start a new Standard (mm).ipt the View Cube shows it is the front plane, but when I finish the sketch and it goes to the Home view, that plane is now horizontal, and the view cube shows the Front plane pointing up, and the Bottom plane pointing forward as compared to when I start a Standard.ipt where the View cube Front plane stays in the front and the top is on top. Basically what it amounts to is the Standard.ipt starts with the XZ plane as the top view with the Y axis pointing up, and the Standard (mm).ipt with XY as the top vew with the Z axis pointing up.  I hope that wasn't confusing, I'll attach a screen shot to make it clearer.
My main concern is if I change the template view cube defaults is that doing something behind the scenes that will come back to bite me later? I thought it might be something to do with 3rd angle vs 1st angle projection, but that seems to be handled in the drawing styles.
I should be OK if I change the template to have the View Cube orient how I expect it to right? The Front of the part should be the Front view and not the bottom like currently is.
Create your own templates for how you want to work. The templates are only just starting points.
blair
Message 2 of 5 (531 Views)
Re: Standard (mm).ipt default orientation?
12-29-2012 10:50 AM in reply to: jimdaug
Think of a flat plate laying on the floor, X & Y are the width and length of the plate and Z is the thickness of the plate. Many NC profile burning/cutting software use X & Y as the profile shape of the plate and Z is treated as the thickness of the profile.
You can change the default sketch plane in the Tools>Application Options>Part:
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.75
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
Active Member
jimdaug
Message 3 of 5 (517 Views)
12-29-2012 03:22 PM in reply to: blair
Right, but why is that not consistant between the templates? Why would Z be up in the mm template and Y up int the inch? if I change the default sketch plane in the options, it will then be wrong in the other template.
blair
Message 4 of 5 (507 Views)
12-29-2012 09:01 PM in reply to: jimdaug
Win7-64
Delta Tau Chi ΔΤΧ
Active Member
jimdaug
Message 5 of 5 (500 Views)
12-29-2012 10:46 PM in reply to: blair
Ok, fair enough.
