Refering Inventor 2014.
I have a problem after some undefined changes done to standard material and Appearances Libraries. When I create new part based on Standard.ipt provided within Inventor installation I got message "Style Conflict": setting in stle library differs from one saved in template: "Lighting: Two Lights". Inventor says about two options. I would rather not change it in Standart.ipt template file but I would like to update that style library. How to do that - where/how to find it to resolve that problem. I would like to keep my standard.ipt working without error messages.
Solved by salariua. Go to Solution.
You need to open the template.ipt file.
Go to Mange Syles and if you want to update the style library.
You have to opotions
Save, if you want to save modifications from part to standard library
or
Update if you want to update the part as per standard library.
In your case you need to click on save to push the chagnes on the part to the library.
