Inventor General Discussion
Distinguished Contributor
dloganbill
Message 11 of 16 (309 Views)
Re: Stainless pipe fittings
10-02-2012 11:58 AM in reply to: cwhetten
cwhetten wrote: And I don't think the difference in material density between carbon steel and stainless steel (on the order of a few thousandths of a pound per cubic inch) is significant (until maybe the 100,000-lb range, and THAT would be a lot of piping).
If my memory servers me correctly, I think there is a 2% difference in densities.  And 2% adds up quickly on the large systems we design.
______________________________________________________________
Autodesk Product Design Suite Ultimate 2014
Inventor Pro 2014 - SP1
Win7 Pro x64
Dell T5500; Xeon E5520 2.27GHz; 15 GB ECC RAM; Quaddro FX4800; SSD
blair
Message 12 of 16 (297 Views)
10-02-2012 12:56 PM in reply to: dloganbill
You need to search around in the Autodesk online Wiki help. It should help you through it.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.60
SpacePilot Pro 3.06.109
Delta Tau Chi ΔΤΧ
cwhetten
Message 13 of 16 (290 Views)
10-02-2012 01:10 PM in reply to: dloganbill
dloganbill wrote:
Is there a published workflow for doing that?
Is your content center on a vault server or do you use desktop content?
dloganbill
Message 14 of 16 (284 Views)
10-02-2012 01:35 PM in reply to: cwhetten
It's on the vault server.
Win7 Pro x64
cwhetten
Message 15 of 16 (273 Views)
10-02-2012 03:19 PM in reply to: dloganbill
If you don't already have a custom writeable CC library, then you need to create one.  You have to do this from the vault server ADMS console.  Once you are logged in to that, you can right-click on the libraries and create a new one.
If you already have a custom writeable CC library, then you are good to go.
Next, you have to make sure that this library (new or not) is available in your project file.  In Inventor, go to the projects editor, select your project file, then click on the Configure Content Center Libraries in the bottom right corner (just above the Done button).  This will pull up a list of available CC libraries.  Make sure the writeable custom library is checked.
Once your writeable library is available, then go to Manage tab > Content Center panel > Content Center Editor.  This will launch the editor window that looks similar to the place from CC window.  This is where what Blair said comes in.  Find the fitting that is closest to what you need.  In your case, that's probably the ASME 16.9 butt-welded fittings, since they are the only ANSI butt-welded option.  Right-click the part family and choose Copy To > [whatever you named your custom library].  This will copy the entire part family with its family table and folder structure into your library.  You can then edit it to your heart's content.
In this case, you will want to edit the family table and change the material, the wall thicknesses, change the schedule designation if you want it to show the "S", filename, part number, description, and anything else I forgot.
dloganbill
Message 16 of 16 (249 Views)
10-03-2012 07:13 AM in reply to: cwhetten
This looks good and simple enough to follow. Thanks for the walk through.
Win7 Pro x64
