Hi Henrik
Vault comes with a Free MSDE (MS SQL 2000) in the installation. This
installation can later be upgraded to Full SQL - either Standard or
Enterprise, if the need arises. Usually this will come in connection with
having more than 10 users or starting to get bigger metadatabses than 2 GB,
which are the limits of what MSDE allows. Regarding the SQL Licenses - that
is determined according to which License model you are running (Processor,
CAL etc.)
Otherwise I would also suggest you to look in the Vault Newsgroup to follow
the lively discussions over there.
Best regards
Uffe Bak
Autodesk Northern Europe
"Henrik Andersson" wrote in message
news:5024610@discussion.autodesk.com...
Hi.
Does anyone know witch license of SQL-Server 2000 that is required to run
vault?
And if the CAL- license is needed for each vault client?
/ Henrik
