Inventor General Discussion
Valued Contributor
danielw88
Message 1 of 10 (1,274 Views)
sprockets
1274 Views, 9 Replies
01-15-2013 08:05 AM
Does anyone have a good place to get 3d models of roller chain sprockets? I've been looking for a while now but i can't find anything that provides the variety or accuracy i need.
danielw88 wrote:
The last time i used it, if i can recall correctly, generated a pair of discs (with not teeth) with a blue, transparent chain mock-up.
The sprockets i need are H80B48, H80B15, H60B60
My memory isn't that great - but I don't recall a release that didn't generate real teeth.
I have never bothered to check the DA generated toothform against my Machinery's Handbook spec generated toothform as sprockets are generally purchased off the shelf and my purpose for doing the geometry myself was simply to use something interesting to demonstrate how to create an iPart.
The chain is generated as a simplified blue, tranlucent representation.
Valued Mentor
Mason-Paul
Message 2 of 10 (1,266 Views)
Re: sprockets
01-15-2013 08:21 AM in reply to: danielw88
You might like to try here http://grabcad.com
Inventor 2014 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Ghz CPU , 32 GB Ram
64bit Windows 7 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Valued Contributor
danielw88
Message 3 of 10 (1,259 Views)
Re: sprockets
01-15-2013 08:35 AM in reply to: Mason-Paul
They had alot, but not what i needed.
Distinguished Contributor
dick_upton
Message 4 of 10 (1,254 Views)
Re: sprockets
01-15-2013 08:40 AM in reply to: danielw88
JDMather
Message 5 of 10 (1,241 Views)
Re: sprockets
01-15-2013 09:06 AM in reply to: danielw88
Are you aware that there is a sprocket generator built into Inventor?
I have an Excel driven sprocket based on Machinery's Handbook specs that you might be interested in if the Design Accelerator sprockets won't work for you.  You might have to edit it to meet your needs.
Give me sample specs for one that you need.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
danielw88
Message 6 of 10 (1,236 Views)
Re: sprockets
01-15-2013 09:10 AM in reply to: JDMather
I haven't used the sprocket/chain feature in Inventor for a while. The last time i used it, if i can recall correctly, generated a pair of discs (with not teeth) with a blue, transparent chain mock-up.
JDMather
Message 7 of 10 (1,233 Views)
Re: sprockets
01-15-2013 09:12 AM in reply to: danielw88
Valued Contributor
danielw88
Message 8 of 10 (1,229 Views)
Re: sprockets
01-15-2013 09:17 AM in reply to: JDMather
Then your memory is better than mine because i just checked and the generator does include teeth on the sprocket discs.
Thanks for your help, other than not having a hub, those sprockets will serve their purpose. I can't belive i had forgotten about that feature.
JDMather
Message 9 of 10 (1,222 Views)
Re: sprockets
01-15-2013 09:23 AM in reply to: danielw88
Simply edit the part to add hub and hole as needed.
Valued Mentor
BLHDrafting
Message 10 of 10 (1,194 Views)
Re: sprockets
01-15-2013 06:00 PM in reply to: danielw88
I give a thumbs up to Traceparts.Has all the sprockets I could ever need.
http://www.tracepartsonline.net
 Do a search or look in here :-
Mechanical systems and components of general use > Flexible drives and transmissions > Chain drives and their components >
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
