Inventor Forum
sprockets
9 REPLIES 9
Message 1 of 10
danielw88
4209 Views, 9 Replies
sprockets
Does anyone have a good place to get 3d models of roller chain sprockets? I've been looking for a while now but i can't find anything that provides the variety or accuracy i need.
9 REPLIES 9
Message 2 of 10
Paul-Mason
in reply to: danielw88
You might like to try here http://grabcad.com
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 3 of 10
danielw88
in reply to: Paul-Mason
They had alot, but not what i needed.
Message 4 of 10
dick_upton
Message 5 of 10
JDMather
Are you aware that there is a sprocket generator built into Inventor?
I have an Excel driven sprocket based on Machinery's Handbook specs that you might be interested in if the Design Accelerator sprockets won't work for you.  You might have to edit it to meet your needs.
Give me sample specs for one that you need.
Message 6 of 10
danielw88
in reply to: JDMather
I haven't used the sprocket/chain feature in Inventor for a while. The last time i used it, if i can recall correctly, generated a pair of discs (with not teeth) with a blue, transparent chain mock-up.
The sprockets i need are H80B48, H80B15, H60B60
Message 7 of 10
JDMather
My memory isn't that great - but I don't recall a release that didn't generate real teeth.
I have never bothered to check the DA generated toothform against my Machinery's Handbook spec generated toothform as sprockets are generally purchased off the shelf and my purpose for doing the geometry myself was simply to use something interesting to demonstrate how to create an iPart.
The chain is generated as a simplified blue, tranlucent representation.
Message 8 of 10
danielw88
Then your memory is better than mine because i just checked and the generator does include teeth on the sprocket discs.
Thanks for your help, other than not having a hub, those sprockets will serve their purpose. I can't belive i had forgotten about that feature.
Message 9 of 10
JDMather
Simply edit the part to add hub and hole as needed.
Message 10 of 10
BLHDrafting
I give a thumbs up to Traceparts.Has all the sprockets I could ever need.
http://www.tracepartsonline.net
 Do a search or look in here :-
Mechanical systems and components of general use > Flexible drives and transmissions > Chain drives and their components >
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
