i have Recreated the model Which was posted From Glennchun of Autodesk in this discussion Example
Attached Part is Recreated one
In this model the sweep Fails
If circle dimensioned equal to wire Diameter
but if circle dimensioned to wirediameter-0.005
Sweep generates
This is not the same case prior to Inventor 2015 release
Sweep wont Fail in Iv 2014 Release
What Definition was changed in Sweep Feature For 2015 Release
Solved by glenn-chun. Go to Solution.
Open compression_spring_2_glenn.ipt
Delete the Sweep and 3d Sketch
Recreate the Helix using 3d Sketch Wrap to Surface Command
Sketch a circle(Wire Diameter) normal to helix Axis
Now try to Create a Sweep using circle has profile
and 3dsketch as path
Sweep Fails
Autodesk has changed Some definitions either with wrap to face or wiith Sweep Definition
Hi Ravi,
The curve type generated from the wrap functionality in Inventor 2015 is different from that in Inventor 2014 and earlier. The new curve type is much faster, much lighter, and yet much more accurate than the old curve type. This change is shown in online help for Inventor 2015 > What's New > General:
I reproduced the sweep failure by following your steps in Inventor 2015. The failure is caused by the new curves from the wrap functionality. Since they are more accurate, each white face shown below self-intersects in Inventor 2015:
There is a simple solution to avoid this kind of self-intersection. Just divide the full circle of the profile into two 180-degree arcs, like this:
Sweeping the two arcs produces more faces, but we can avoid the self-intersection errors:
Attached is a new part that I created in Inventor 2015. Benefited from the new, lightweight curve type, its file size is only 861 KB, which is 39% of the Inventor 2014 part (2.2 MB). Also, the speed of the sweep operation is much faster because of the new curves for the sweep path. It takes 20 seconds to see the preview graphics when you double-click the sweep feature in compression_spring_2_glenn.ipt that contains the heavy curves from wrap. It only takes 2 seconds to do the same in compression_spring_2_glenn_Inv2015.ipt that contains the lightweight curves.
Hope this helps,
Glenn
(Formerly a ShapeManager developer. Currently a T-Splines developer)
Thanks you Glenn for your Speedy response
i think the failure is because of Sweep Definition not with 3d Sketch Wrap to Face
The same issue will persists even with 3dsketch helix command
Sweep Fails
(Autodesk has not changed anything with 3d sketch Helix Command)
Sweep will not fail in Inventor 2014 version with same parameters
So this not a problem with 3d sketch wrap to face or 3d sketch Helix
its only sweep definition
i knew Sweep Feature has enhanced with New Twist option
Attached Sweep Sucess prior to inventor 2015 version
Sweep Failure in 2015 version
Both with same Parameters and Procedure
Sweep Sucess in IV2011
Sweep failure in IV2015 Version
Hi Ravi,
I cannot reproduce the issue that you mentioned about sweeping along a regular helix. I see the following consistent behaviors in both Inventor 2014 and Inventor 2015.
Case #1: Open the attached sweep_full_circ_along_helix_inv2014.ipt, sweep the full circle along the helix, and you will see sweep fail with a self-intersection error. This is expected since the helix pitch is equal to the diameter of the full-circle profile.
Case #2: Open the attached sweep_two_arcs_along_helix_inv2014.ipt, sweep the two-arc profile along the helix, and you will see sweep succeed. This is expected because this trick has been available since Inventor 2014.
If you have any Inventor 2014 part that shows a different behavior in Inventor 2015, please attach the part here and post steps to reproduce.
Glenn
Case1:Sweep Success Prior to Iv2015 version
open Sweep_Success_Helical_Curve_Sweep_IV2011.ipt
and follow these steps attached in the image
Sweep Success if u used Guide Surface option
Case2:Sweep Fails in Iv2015 version
Delete the Sweep and try to recreate as mentioned in above image
Sweep Failsssssssssssssssssssssssss
Hi Ravi,
Thanks for attaching your parts. In your parts, the profile lies on Work Plane1 that does not contain the helical axis.
We strongly recommend to draw the profile on a plane that contains the helical axis. If you haven't noticed, that recommendation is actually forced in the Coil command. If you redefine Sketch1 to be placed on YZ Plane, you will see the consistent behaviors that I described earlier.
Glenn
Sketch profile is normal to helical Curve
select curve and Startpoint/Endpoint to create workplane
Then create a Sketch Profile on Workplane
I understand that your profile is normal to the helix. The problem is that the plane normal to the helix does not contain the helical axis. If you look at the model using Top View, you will see that YZ Plane contains the helical axis but Work Plane1 does not.
Glenn
ok Anyways
The Things which worksout prior to IV2015
doesnt work in IV2015
Why?
Hi Ravi,
Here's a summary of the behaviors of sweeping a circular profile along a regular helix under the following two conditions:
Inventor 2013:
Inventor 2014:
Inventor 2015:
The behavior of the guide-surface sweep in Inventor 2013 (or earlier) is wrong because it is harmful to create a self-intersecting surface.
My recommendations:
Glenn
Glenn Wrote:
i will install Inventor 2014 tommorrow and will confirm with you that
Anyway
Thank You Very Much Glenn
You have saved Lot of time For me
Basically i was Developing ilogic code to Create a Spring with Dead Coils and Active Coils
First
it asks user to Enter
1.Helix radius
2.WireDiameter
3.No oF Turns For Dead Coil
4.No of Turns For Active Coil
5.Active Coil Pitch Index
Then All user Parameters and Geometry will be executed by ilogic Rule based on above entered inputs From the User
This Code could be usefull to many others
Attached is the Code and Video+
https://www.youtube.com/watch?v=ldXDb-0yLqY&feature=youtu.be
Code Attached
