Good morning,
I have included a picture and a file of a spring. The dimensions on the IPT are good, but I cannot figure out how to get the end transitions the way I want, per the picture. I tried doing a simple extrude just to get my length but end up with sharp corners that I dont like and dont want the spring shop to replicate like that...
Any help would be grand!
tks!
Solved by -niels-. Go to Solution.
I probably completely messed up your spring's values, but is this what you're trying to do?
You can control the flat ends of a spring on the last tab in the coil command.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Hi Niels,
Nope that is exactly what I was looking to do. I will dig into the file to see how you managed it.
Appreciate the help, and quick response! 🙂
tks!
Niels van der Veer
The Netherlands
