I have followed every direction in the wikihelp spline and surfaces portion when creating the mouse but, for some reason, every time I try to split the horizontal section I get a message saying "The attempted operation did not successfully complete due to unforeseen problems. Try with different options or inputs." But when I go to split the vertical spline it splits just fine. What can I do to fix this? Thank you.
Solved by JDMather. Go to Solution.
Attach your ipt file here.
Extend the edge of the surface.
It must completely cut the solid.
Also, Sketches 4,6 & 8 are not fully constrained. Add construction line from projected orgin to midpoint of splines.
Can you post the url to the wiki page so that I can submit suggested clarifications.
file:///C:/Program%20Files/Autodesk/Inventor%202013/Local%20Help/index.html?url=files/GUID-FAB20788-... It is under Spline and Surface
You put a link to your hard drive.
I was execting an internet url to the on-line wiki.
Well I'll see if I can find the page.
http://wikihelp.autodesk.com/User:drafts/505206
@T.pot wrote:The top URL that you sent me is basically the same thing.
It should be exactly the same thing - I posted the url here for others that might come across this thread in a search since you posted a path to your C drive that we are not likely to have access to.
I then posted a correction to the page, but I guess they didn't like my suggestion.
