Inventor Forum
Splitting the horizontal spline
7 REPLIES 7
Message 1 of 8
T.pot
750 Views, 7 Replies
I have followed every direction in the wikihelp spline and surfaces portion when creating the mouse but, for some reason, every time I try to split the horizontal section I get a message saying "The attempted operation did not successfully complete due to unforeseen problems. Try with different options or inputs." But when I go to split the vertical spline it splits just fine. What can I do to fix this? Thank you.
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: T.pot
Attach your ipt file here.
Message 3 of 8
T.pot
in reply to: JDMather
Mouse Spline file. I am not the only one that this has happened to.
Message 4 of 8
JDMather
in reply to: T.pot
Extend the edge of the surface.
It must completely cut the solid.
Also, Sketches 4,6 & 8 are not fully constrained.  Add construction line from projected orgin to midpoint of splines.
Can you post the url to the wiki page so that I can submit suggested clarifications.
Message 5 of 8
T.pot
Message 6 of 8
JDMather
in reply to: T.pot
You put a link to your hard drive.
I was execting an internet url to the on-line wiki.
Well I'll see if I can find the page.
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/0127-Inventor127/0514-Splines_5...
http://wikihelp.autodesk.com/User:drafts/505206
Message 7 of 8
T.pot
The top URL that you sent me is basically the same thing.
Message 8 of 8
JDMather
in reply to: T.pot
It should be exactly the same thing - I posted the url here for others that might come across this thread in a search since you posted a path to your C drive that we are not likely to have access to.
I then posted a correction to the page, but I guess they didn't like my suggestion.
