I've been working on a trailer frame which I've created using the frame generator. As the design has devleoped, it has become apparent that the best way to manufacture it is in two parts and then to bolt them together later. Is there a (simple) way to be able to split the frame into two sub-assemblies?
Hi spackle42,
In addtion to the previous suggestions, I think you could save a copy of your existing frame assembly and then place the original and the copy into a new top level assembly file. Then edit one of them and delete half of the frame members, then edit the other one and delete the other half of the frame members.
I hope this helps.
Curtis
