Inventor Forum
Splitting a Generated Frame
2 REPLIES 2
937 Views, 2 Replies
I've been working on a trailer frame which I've created using the frame generator.  As the design has devleoped, it has become apparent that the best way to manufacture it is in two parts and then to bolt them together later.  Is there a (simple) way to be able to split the frame into two sub-assemblies?
2 REPLIES 2
brendan.henderson
2 methods come too mind. 1) with existing frame members select the members to be grouped into the 1 assy and demote them to a new assy. I see you're on 2014 so being demoted the members retain their link to the original frame sketch/assy and be edit from there. 2) Use the same frame sketch inserted into 2 different assy files and apply the members to be grouped into the 2 assy's. Personally I would do option 2 but this would require you to create 2 new assy files so your existing work would be useless.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Hi spackle42,
In addtion to the previous suggestions, I think you could save a copy of your existing frame assembly and then place the original and the copy into a new top level assembly file. Then edit one of them and delete half of the frame members, then edit the other one and delete the other half of the frame members.
I hope this helps.
Curtis
