By allowing you to split a face you can delete or even thicken that newly
created face.
When you delete a face and don't heal you have created a surface. When you
delete the face notice that the icon at the top of the browser has changed
from a box solid to a quilt surface.
This allows you to add addtional surfaces, stitch them in, and then thinken
to create a new solid.
"Kevin Vallelunga" wrote in message
news:4071871a$1_1@newsprd01...
> What do you use the split tool for if you keep both halves? I typically
use
> to remove one side of something. I understand if to split a bi-colored
face.
> But from a modeling perspective just curious.
> Also why delete faces if heal is turned off? If I delete a face and don't
> heal, isn't the solid a non-manifold solid?
> Kevin V.
